Sponsored by: CARiD
one quick Q..
Old Jun 20, 2006 | 12:04 PM
z28_n_tx's Avatar
Default one quick Q..
im replacing the temp sensor ...just wanted to know if i should put anything on it like thread lock w/out affecting anything...i got a P0118 code, would i need to reset the car after i install the new temp sensor???
Old Jun 20, 2006 | 12:20 PM
2001NBMZ28's Avatar
Helms says to use sealer PN 12346004 or equivalent (whatever that is). Don't overtighten - it's only 15 lb ft. No need to reset the PCM, light will go off after 3 ignition cycles diagnostic runs and passes.
