Sponsored by: CARiD
Need Key And Ignition Help!!!!
Old Jul 11, 2006 | 06:46 PM
xxxtreme36's Avatar
Default Need Key And Ignition Help!!!!
ok so after a long fight with the fuel system and a fuse i get the car running. While trying to find what the starting issue was a did replace the ignition switch, and then i replaced the neutral safety switch, after finding out it wasnt the neutral switch i put the old one back in. Now the car will start and run.
My problem: the key will not turn to the off position so i can take the key out. Please help also my breaks feel alot more squishy if you will. Does that have something to do with the ignition switch, i know the brake safety cable is in right and locked like its supposed to be. where should i start
Old Jul 11, 2006 | 08:10 PM
xxxtreme36's Avatar
come on i know someone has some sugg
Old Jul 19, 2006 | 10:09 AM
lastofthebird's Avatar
Default Ign prob
When you try to turn off the ign. does it move at all? Does it stop hard or does it feel like you can almost turn it off but you would have to force it?
