Sponsored by: CARiD
battery problem
Old Jul 22, 2006 | 10:33 PM
95zpro's Avatar
Default battery problem
has anyone ever encountered a leaking battery ? Mine seems to be leaking from the caps; after I run the car hard I pop the hood and it's wet all over the battery but the caps are all tight ? Anybody ever run into this problem and what is the fix; battery is not even a year old(I should have gotten an Optima or maintenance free).
Old Jul 23, 2006 | 04:33 PM
00'WS6Rocket's Avatar
Hmm I get another battery something is obviously wrong with it, are you sure its battery acid and not anything else ie. antifreeze?
Old Jul 23, 2006 | 05:24 PM
sunsetorangessls1's Avatar
If its a delco then yepp i had that problem with 4 thou miles on the clock. The battery terminals started leaking then just fell off.
word of wisdom replace the battery befor it leaks over your engine bay and eats everything it touches....
J
Old Jul 23, 2006 | 05:28 PM
2001NBMZ28's Avatar
Don't know what's going on if it's leaking from the caps, terminals yes - but if it's only a year old it should be under a free replacement warranty - bring it back.
Old Jul 23, 2006 | 05:29 PM
95zpro's Avatar
thank you all for the advice; I'm going to check the terminals but definately going to replace because it looks like its discoloring one of my intercoolers !!!
