Sponsored by: CARiD
Starting Problem !
Old Nov 14, 2006 | 01:19 AM
FormulaZ's Avatar
My 95 Z is currently having the same problem I havn't done everything on the list but so far as been checked it seems to point at the same issue.
Old Nov 14, 2006 | 08:53 AM
98Camarod's Avatar
mine was the ignition relay.
Old Nov 15, 2006 | 01:49 AM
FormulaZ's Avatar
Decided to open her up and change out the cap and rotor it was coming up time, not sure if thats the prob but will see as work progresses.
Old Nov 15, 2006 | 09:13 AM
98Camarod's Avatar
Well you have an lt1. If you are not getting spark try the ignition module. But it could also be time for that optispark to go out too.
Old Nov 17, 2006 | 01:44 AM
FormulaZ's Avatar
Well little by little been working on her before work and now stuck. I cant seem to get the harmonic balancer off, tried using a puller didnt work and even tried pulling it myself. Any advice? Going to see about another puller tmw, but figured it ask.
Old Nov 20, 2006 | 01:10 AM
FormulaZ's Avatar
Well it was indeed my cap and rotor, finally got it done. Had to get a gear puller and balancer came off pretty easy. Only problem now is that my radiator light stays on and check gauges light as well.
