Sponsored by: CARiD
*HELP* P0300 Multi Misfire
Old Jul 31, 2006 | 09:17 PM
shwagg's Avatar
Default *HELP* P0300 Multi Misfire
I was out today on the freeway at different speeds and I have never missed a gear. then I get off and get to a light and the engine is running ruff with a definate miss. I mean the shifter is shaking my hand off at low rpm take off speeds. Then the ses light comes on and flashes. I limp it home and get the predetor on it and it gives me p0300. multi misfire. I do have a sqeeky belt that only starts after its up to temp and its more of a ringing kind of noise. I do not have a K&N, have not washed the engine bay in awhile. I have not had any problems up til now. I do realize the predetor is not the cause but i still went back to factory tune just in case. The car is bone stock except for the SLP Lid and Skip shift eliminator. I have not changed the plugs or wires the car only has 26,600 those wires and plugs should have plenty of life. If it was a crank sensor wouldnt the car be dead in the water? If all else fails I just talked to my neighbor who is the service manager at the local pontiac dealership and he said he could get it in and charge me 35.00 an hour.What could this be at 26,600 miles? Any insite would be great, especially if you have seen this before. Thanks in advance for any help.
Old Jul 31, 2006 | 09:40 PM
Nine Ball's Avatar
LS1Tech Co-Founder
What year is your car?
Misfires can be caused by several things:
-bad spark plug wire
-bad/clogged fuel injector
-bad spark plug
-bad coil pack
-bent pushrod
-broken valvespring
-bent valve
-broken piston ring land
P0300 is a common code for cars with cams in them, are you positive your car is 100% stock internally?
Old Jul 31, 2006 | 09:55 PM
shwagg's Avatar
The car is a 2001 WS6. I just finished going through the plugs and all have what seems to be spark. I used a spare plug and unplugged one spark plug at a time and all had spark but this is now way to be sure there is enough spark though. I then removed the plug and two of them looked wet but all had a tan color and where the stock Denso. The gap was set to .060 (looks large). What is the the flow rate of the stock injectors. I might have to go with the ford SVO injectors but I am not sure which ones to get without having to change the fuel pressure regulator. It did not give any cylinder number just the P0300.
Old Aug 2, 2006 | 08:04 AM
shwagg's Avatar
Alright, I found the problem to be two bad spark plug wires, #1 cylinder coil pack, and a bad spark plug. Thanks to everyone who helped. Take care and be safe.
