Sponsored by: CARiD
Engine Starting Problems TECH HELP NEEDED!
Old Aug 8, 2006 | 01:56 PM
Firebirdgm2000's Avatar
Default Engine Starting Problems TECH HELP NEEDED!
About a week ago I had removed my calipers and rotors so I could powder coat and rebuild them (*ask if you want them done).... anyways I went to turn my car over the next morning and it was troublesome to keep on for the first few seconds, if I didn't hold the gas down a bit it would turn off and if I revved it too high it would shut down I had to keep tapping the gas like an old chevy to keep it from stalling out....
I used my scanner to try and find the problem the code came up as P0102 ( MAF OR VAF CIRCUIT LOW INPUT) ..... So I took a gander under the hood at all the fuses and noticed that the Eng Sen 20Amp fuse was blown, so I simply replaced it and tried to start the car instantly the fuse blew and the starting issues didn't change (no effect)....... i've also had about 2 months issue with my exhaust rattling i'm thinking it's the cat but I feel no power loss really i'm not 100% on that.... I have an o2 sensor simulator connected so i dont run codes
i'm not sure if I have a coroded wire (grounded perhaps?) or maybe some part of the maf needs to be replaced.... help would be appreciated... here are my car specs
SPECS:
2000 pontiac Firebird 3.8L V6
Fast toys intake + Ram Air intake and air box
B&B exhaust + random tech cat W/ O2 SENSOR SIMULATOR
