Sponsored by: CARiD
Window a little crooked
Old Aug 12, 2006 | 11:57 AM
kapedogg's Avatar
Default Window a little crooked
My passenger side window doesn't close completely. The motor is fine, it is just out of alignment and a little loose. How can you adjust these. I know I read about it somewhere, but I can't find it anymore.
Old Aug 12, 2006 | 02:18 PM
2001chevroletz28's Avatar
take the panel off look in there for the adjustments should be pretty easy
Old Aug 12, 2006 | 04:51 PM
LTSpeed's Avatar
Each of the tracks has some adjustment. Just look for the one that's loose and put it back where it was. Usually you can see the fastener marks where it was put together at the factory.
Old Aug 17, 2006 | 07:49 AM
kapedogg's Avatar
I found the adjustments which seem to be in tact, and messed with them a bit, but I found that the window itself can be pushed/pulled up and down on the rear side of the window, which makes it pivot. The pivot point might be the gear on the motor, I can't really tell, which means the motor might actually falling apart on the inside or something so it doesn't hold tight. Anyone else run into this? It would make it pretty easy to steal cause you can get the back corner down about 1/4 inch!?!
