Electrical System Issue, would like some help please.....
If you have to give it gas to keep it running, maybe you have another issue causing a low idle. Maybe dirty MAF or another sensor going bad or something. Does your CEL ever come on? Is your car automatic? Will the same symtom happen in neutral or park?
check that because it effects the charging of the battery.....also when you turn the AC on, for it to fall is normal...mine goes from around 13.5 to 12.8....run a volt meter on the wires and see if there carrying the right load...
