Sponsored by: CARiD
a/c smells like ass
Old Sep 26, 2007 | 09:25 AM
firebirdhorn's Avatar
Originally Posted by rmpitzer
My car has recently developed this problem. Where can I find the drain to see if it's plugged?
Im not 100%, but my unles 2003 Oldsmobile Aurora did this two weeks ago and was leaking inside the car, leaking so bad, it was just peeing out of this little hole from all the mold spores built up in there. It was leaking on the passenger side under the dash. Not sure if it would be the same in an f-body, but its worth a shot.
Old Nov 10, 2007 | 06:20 PM
3800RS's Avatar
where exactly is the ac drain ?
Old Nov 11, 2007 | 12:57 PM
rmpitzer's Avatar
Well, apparently there isn't a drain hose....just a hole in the bottom of the evaporator case for the water to drain out.
Here is a thread where I asked about it.....
https://ls1tech.com/forums/showthrea...28#post7857728
-Rich
Old Nov 11, 2007 | 02:36 PM
_JB_'s Avatar
-Rich
Yep, mine was clogged and started to leak inside the car. It's not hard to get to, just don't jam something in there to rupture and evaporator core.
