Sponsored by: CARiD
Found in glove box What is it?
Old Sep 3, 2006 | 07:25 PM
Grimes's Avatar
build sheet....mine was in the glovebox!
Old Sep 3, 2006 | 07:37 PM
Brandon Boomhauer's Avatar
get it laminated if you care to keep it for some time. encapsulation will help preserve it.
Old Sep 5, 2006 | 10:10 AM
CAMJAG's Avatar
Originally Posted by LILWS6
O one last quick question anyone know what the WS9 option is?
I think that might be the option code for the Ram Air Hood
Old Sep 13, 2006 | 08:59 AM
1CAMWNDR's Avatar
No. WS9 is the code for going from V6 'bird to V8 Formula. I have WS9 on a non ram air Formula. There is a second code for going fron Formula to Trans Am.
Old Sep 13, 2006 | 11:41 AM
The Spot's Avatar
Ok so its a build sheet for the car i guess i'm not getting something .... what exactly is the "build sheet" what information is on it and why would you want it?
Old Sep 13, 2006 | 01:29 PM
joshp14's Avatar
It's the sheet that runs down the production line at the manufacturer. Its attached to your car and shows what your car came with for options. Its usually desired in older cars more than new ones. A lot of times they get tossed at the dealership when they do the PDI (pre delivery inspection). We get new cars in all the time and I throw these things away without thinking twice.
Most people dont want them, but if you are a car enthusiast then its something cool to have.
Old Sep 13, 2006 | 01:32 PM
joshp14's Avatar
I also just ran a VIS on your vehicle based on your VIN, and I can pretty much pull up all the info on that sheet thats a little easier to understand:
VIN 2G2FV22G712145400
VEHICLE BUILD
Merchandising Model : 2FV87 -2001 FIREBIRD TRANS AM
Gross Vehicle Weight Rating : 1948 kg (4295 lb) Order Number : DDMM9H
Build Date : 04/09/2001 Build Plant : 212F - STE THERESE ASSEMBLY GM-CANADA
OPTION CODES
AAA - STANDARD EQUIPMENT PROCESSING OPTION AG1 - POWER SEAT, DRIVER 6-WAY
AK5 - DUAL FRONTAL AIR BAGS AQ9 - CUSTOM BUCKET SEATS W/ADJUSTABLE LUMBAR SUPPORTS
AU0 - REMOTE KEYLESS ENTRY AU3 - POWER DOOR LOCKS
A31 - POWER WINDOWS BBS - HURST SHIFTER
CAF - HANDLING CHARGE-ST. THERESE TO AMERICAN SUNROOF CC1 - LOCKING HATCH ROOF, REMOVABLE
C60 - AIR CONDITIONING, CUSTOM DE4 - HATCH ROOF SUNSHADES, REMOVABLE
DG7 - DUAL POWER SPORT MIRRORS DL5 - DECAL ROADSIDE SERVICE
FE4 - RIDE & HANDLING SPECIAL SUSPENSION SYSTEM FE9 - 50-STATE LOW EMISSION VEHICLE
GU6 - 3.4 RATIO REAR AXLE G80 - LIMITED SLIP TORSEN REAR DIFFERENTIAL
IL2 - TRIM INTERIOR DESIGN J65 - BRAKES, PWR 4-WHL,DISC FRT & RR
K43 - 102 AMP GENERATOR LS1 - 5.7 LITER SFI V8 ENGINE
MM6 - TRANSMISSION, 6-SPEED MANUAL MN6 - TRANSMISSION, 6-SPEED MANUAL
NF7 - FEDERAL LOW EMISSION NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT ****
NW9 - TRACTION CONTROL, ELECTRONIC PBT - TEMP. WHL & TIRE-UPFITTER DLVY
QB6 - 17" HIGH POLISHED ALUMINUM WHEELS QFK - TIRES, P275/40ZR17 SPEED RATED
R7X - SECURITY PACKAGE CONSISTS OF: THEFT DETERRENT SYSTEM REMOTE KEYLESS ENTRY R9P - POWER PACKAGE INCLUDES: POWER DOOR LOCKS RETAINED ACCESSORY POWER, POWER WINDOWS INCLUDING EXPRESS DOWN DRIVER'S SIDE DUAL POWER SPORT MIRRORS POWER ANTENNA
SLM - SALES STOCK ORDERS STE - ASM PLT ST. THERESE
T43 - SPOILER, REAR DECK LID T78 - HEADLAMP CONTROL DELETE
UA6 - THEFT DETERRENT SYSTEM UB3 - RALLY GAGES W/TACHOMETER
UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS U1S - REMOTE COMPACT DISC CHANGER, TRUNK MOUNTED, 12 DISC CAPACITY
U75 - POWER ANTENNA VM3 - BUMPER STD IMPACT 5 MPH FRT &RR
V12 - POWER STEERING COOLING SYSTEM V73 - VEHICLE CERTIFICATION U.S.
WS6 - RAM AIR PERFORM.& HANDLING PKG: * RAM AIR INDUCTION SYSTEM * FUNCTIONAL AIR SCOOPS * 17" HIGH POLISHED ALUMINUM WHEELS * P275/40ZR17 SPEED RATED TIRES * SPECIFIC LOW RESTRICTION DUAL EXHAUST SYSTEM * SPECIFIC TUNED SUSPENSION * POWER STEERING COOLER WS9 - FORMULA OPTION
W54 Y82 - TRANS AM OPTION
1AY - ORDER MODIFICATION STOCK 1SA - OPTION GROUP - 1SA
11U - PAINT, PEWTER METALLIC 19I - INT TRIM, EBONY
192 - TRIM, EBONY 6BT - COMPONENT FRT LH COMPUT SEL SUS
7BT - COMPONENT FRT RH COMPUT SEL SUS 8TJ - COMPONENT RR LH COMPUT SEL SUSP
9TJ - COMPONENT RR RH COMPUT SEL SUSP
Old Sep 13, 2006 | 01:40 PM
joshp14's Avatar
I can also pull up your build date, warranty info, service history, etc:
Warranty Start Date : 08/21/2001
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer :
FOSTER PONTIAC, INC.
3636 S 27TH ST
MILWAUKEE , WI 53221-1396
(414) 282-5000
According to the service records below, you've had the engine replaced, fuel injector, o2 sensor, etc...see below:
R.O Date R.O Number Type Labor Operation Odometer Reading
10/15/2004 089305 # J1840 - ENGINE, UNIVERSAL - REPLACE 40871 miles
10/15/2004 089305 # J5650 - INJECTOR, FUEL - REPLACE 40871 miles
10/15/2004 089305 # J6372 - SENSOR, OXYGEN - REPLACE 40871 miles
01/10/2003 075024 # N2145 - SWITCH - DOOR WINDOW - LEFT FRONT - REPLACE 20202 miles
01/10/2003 075024 # N3315 - MOTOR - DOOR WINDOW - LEFT FRONT - REPLACE 20202 miles
10/11/2002 983314 # T2020 - TOWING 18334 miles
05/03/2002 372950 # N6648 - WIRING AND/OR CONNECTOR - SEAT SYSTEM - REPAIR OR REPLACE 13066 miles
05/03/2002 372950 # Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 13066 miles
04/09/2001 A45400 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old Sep 13, 2006 | 02:31 PM
jpat1023's Avatar
haha @ new window motor at 20,000 miles!
Is that a engine replacement at 40800??
Old Sep 13, 2006 | 07:52 PM
grb's Avatar
grb
Take a close look at it. If it has the numbers 0, 1 or 2 any or all in any order whatsoever, that is a code for "there is a bomb in the spare tire well". Don't even think about checking it for yourself. Go straight to a dealer and tell them your problem. They will know exactly what to do!
Old Sep 13, 2006 | 08:25 PM
slowpoke96z28's Avatar
the dreaded J1840. its my least favorite labor op. if i remember right, it is for engine replacement. if joshp14's SI can show labor time guides, he can say for sure.
Old Sep 13, 2006 | 09:33 PM
  #32
joshp14's Avatar
Yup it sure is....
Engine, Universal - Replace
OPERATION NUMBER: J1840
Note: Goodwrench Engine.
Note: For check toe-in, refer to operation E2000 and add times to regular hours column.
Automatic Transmission LABOR TIME: 11.6
Manual Transmission LABOR TIME: 12.5
With Engine Oil Cooler ADD: 0.3
Old Sep 13, 2006 | 09:41 PM
  #33
grb's Avatar
grb
Engine replaced. Bomb in spare tire well. Not good.
Old Sep 13, 2006 | 09:52 PM
  #34
Ehatcher's Avatar
wow , sorry to hijack a thread , but i would be interested in knowing my T/A's service records and all that jazz, seeing that i bought the car used with 70k on the odometer
Old Sep 13, 2006 | 10:55 PM
  #35
Originally Posted by joshp14
Yup it sure is....
what sucks the most is that the "proper" P/N gets you a corvette engine, so you have to swap the pulley, oil pan, and something else(can't remember), but the J1840 doesn't pay time for that.
Old Sep 13, 2006 | 11:35 PM
  #36
Phoenix 5.7's Avatar
i got my sheet like that. was in my glove box when i got the car. the previous owner found it. joshp14, think u could do service checks like that for my cars? i can pm u the vins
Old Sep 13, 2006 | 11:55 PM
  #37
joshp14's Avatar
Yes all I need is the last 8 digits of the VIN. Keep in mind the service records are only available if the service was performed at GM dealerships.
Old Sep 22, 2006 | 12:53 PM
  #38
2kg4u's Avatar
Each department in the assembly plant generates a separate build sheet - body, chassis, paint, trim, engine line, etc. Just because you find one of these sheets doesn't mean it is a comprehensive build sheet for the vehicle.
Old Sep 22, 2006 | 01:52 PM
  #39
grb's Avatar
grb
That's a bummer!
Old Sep 22, 2006 | 05:34 PM
  #40
bww3588's Avatar
Originally Posted by RPM WS6
Holy ****!
That looks like a build sheet.
Very cool. I wish I had one for my cars. Usually the dealers toss them out when they prep the car. Looks like you got lucky.
yeah, Holy ****, thats exactly what i said. when i worked at the ford dealership, they came laying on the back seat. we just threw them away.
