Clear Coat
-Thanks Brandon
The few hundred dollars that a shop will charge you to fix it is much better than fighting with a factory rep.
If you have rust through, that is part of a federal warranty and even though the shop does not want to mess with GM is suppossed to cover it. I would suggest contacting GM about the rust through you are having.
I actually just finished up spraying behind the rear tires today, came out badass for my first metallic blend. I gotta do the rockers tommorow and the fender flares monday. $200 in materials and the satisfaction of doing it myself.
