Sponsored by: CARiD
Question about Cooling Fan turn on sequence
Old Sep 9, 2006 | 12:57 PM
BadgeZ28's Avatar
Default Question about Cooling Fan turn on sequence
the car is a 01 Z-28. I am wondering how the fans sequence on? Looks to be three relays for the two fan system. I am replacing the fans with aftermarket units to make room for a supercharger. Thanks.
Old Sep 9, 2006 | 01:59 PM
slowpoke96z28's Avatar
relay 1 funs both fans at low speed. relays 2 and 3 run the fans at high speed.
Old Sep 10, 2006 | 11:57 AM
Low N Slow's Avatar
Low speed the fans run in series, the ground from the first fan goes thru relay #2 and on to the second fan. High speed the first fan grounds thru the second relay and the second fan gets direct 12v from the third relay.
