Sponsored by: CARiD
missfiring need HELP!!!
Old Sep 9, 2006 | 02:15 PM
Emoney97ss's Avatar
Default missfiring need HELP!!!
last i was driving and was doing about 80 in 3rd and shifted back down to 2nd on accident and then it was only for a few seconds and then i pushed the clutch back in, it started to lose power so i turned it off.... so when i got off the freeway i turned it back on and it was fine... i got home and it start running rough around 800 rpms... then the service engine light came on... i went to autozone and the code was a p0303 miss firing number 3... so someone please help i'm a little scared to drive it now, cause i cleared the code and it came back at idle.... it runs fine when i'm gasing it but at idle it runs rough....
Old Sep 9, 2006 | 06:30 PM
joshp14's Avatar
Check the number 3 plug and plug wire. Make sure the wire is snapped on both the coil and the plug properly. Number 3 is the second one back from the front of the engine on the driver side. Be thankful its not #8.
Old Sep 9, 2006 | 08:19 PM
Emoney97ss's Avatar
ok thanks a lot....
