Sponsored by: CARiD
LT1 in thirdgen
Old Sep 10, 2006 | 08:53 PM
Burning Rubber's Avatar
Default LT1 in thirdgen
I just put an LT1 in a thirdgen camaro and I was told that I didnt need the crankshaft position sensor, so I didnt put it in. Could that cause me to have no spark?? That is the only thing I can think of that it could be. Any help would be appreciated!
Old Sep 11, 2006 | 09:54 AM
01WS6er's Avatar
Every engine that I know of that has a crank shaft sensor uses that sensor to crank. I don't know who told you U did not need it, but that is crazy. To run the Lt1 You would use a Lt1 puter. The puter has an input from the crankshaft sensor. ???????
Old Sep 11, 2006 | 03:09 PM
thanks man i guess i just gotta put that thing back in there. I need some sort of spacer though because the crank sensor rubs the timing chain. I suppose i could make a spacer or somethin.
Old Sep 11, 2006 | 03:19 PM
96lt1m6's Avatar
93-95 lt1's did not come with a crank sensor!the 96/97 did however.
the obd 2 conversion to obd 1 deletes the use of the crank sensor.
what year lt1
what year pcm
you may have a bad opti,icm or coil!
please give more details so you can be helped out
Old Sep 11, 2006 | 03:33 PM
01WS6er's Avatar
i totally forgot about the obd thing. It has been a long time since I have fooled with any lt1 stuff even though I am saving for my build to put in my truck
Old Sep 12, 2006 | 05:03 PM
its a 1996 motor and computer. I am just going to put the sensor back in. But I need some sort of spacer because the piece of the sensor that goes on the end of the crank rubs the cloyes double roller timing set.
Old Sep 12, 2006 | 06:43 PM
96lt1m6's Avatar
if you are using the 96/97 pcm you need to have the cps installed.http://www.madz28.com will tune an obd1 pcm for you which will delete the cps and rear o2s etc.very good reputation
yeah i know,you Ls1 guys forgot all about us minimum wage brothas on your way to the top J/K
