Sponsored by: CARiD
p1416 code??
Old Sep 15, 2006 | 03:11 PM
MonteHawk's Avatar
Default p1416 code??
The SES light came on, scanned it with ProScan and it showed a code: 1416 powertrain: secondary air injection (air) system bank 2
OK, so I got a problem on the passenger side but what exactly is it?
Looked online but was unable to find a good chart listing or database. What do you use?
Thanks!
Old Sep 15, 2006 | 03:21 PM
2001NBMZ28's Avatar
It's most likely just a clogged passenger side air check valve. It's screws into the metal air tube coming of the exhaust manifold, then connects with a hose clamp on the other side. Easy to replace yourself and not expensive. GM PN is 12565503.
Old Sep 19, 2006 | 10:42 AM
VA2001SS's Avatar
I just had the same code and swapped out both air check valves while I was at it, code is gone!
