Sponsored by: CARiD
steering rack noise???
Old Sep 15, 2006 | 06:32 PM
pwrtrip75's Avatar
Default steering rack noise???
Its kinda of a creaking noise similar to a dry ball joint when you turn the steering wheel. The noise is coming from the rack itself (center) not anywhere near the steering column or joint.
Under the rubber boot (cv looking boot) anyone know if its servicable or is it junk? whats under there?
Only does it when weight is on it also. jacked up in the air it wont do it.
Old Sep 24, 2006 | 03:05 PM
SHINER's Avatar
would like to know aswelll
Old Sep 26, 2006 | 11:02 AM
mooreperformance's Avatar
I had the same problem, I put in on the lift at work and just tightened the bolts that holds the stearing rack to the frame. No more popping.
Old Sep 26, 2006 | 12:24 PM
SHINER's Avatar
i super glued my boot back together...lol talk about being cheap...
