Sponsored by: CARiD
Some 02 z28 issues
Old Sep 16, 2006 | 10:19 PM
KevsfastZ's Avatar
Default Some 02 z28 issues
Hey guys,
Got a few questions for you guys to pick your brains at. First off, it's a 2002 Z28 mods listed in sig. The problems,
1. Motor seems to cut out for a split second when driving normally in 2nd gear when lightly on the throttle; feels as if I were to shut the car off.
2. When I power shift, 90% of the time it will throw a code, "random multiple cylinder misfire", clear the code and doesn’t come back.
Any suggestions are greatly appreciated. BTW, car runs perfect, and when power shifting I’m not bouncing off the limiter.
Thanks in advance,
Kevin D
Old Sep 16, 2006 | 10:35 PM
Tainted's Avatar
how amny miles are on the car? have you done a tune up recently?
You may need to do plugs/wires/fuel pump/injector cleaning and such. the misfire can be your plugs and wires, and the car feeling like its about to shut off could be your feul pump warning you its on its way out.
Old Sep 16, 2006 | 10:42 PM
KevsfastZ's Avatar
Car has 60k, did plugs about 500mi ago, but has been cutting out like that before the plug change. This only happens in second gear when very lightly on the throttle, no other time.
Old Sep 16, 2006 | 10:45 PM
Tainted's Avatar
hmmm that is a rather strange problem. does it stutter when it does it/backfire anything like that? it may have something to do with your TPS
Old Sep 17, 2006 | 10:44 AM
KevsfastZ's Avatar
Well its real quick, and sometimes it will backfire.. very strange
Old Sep 17, 2006 | 10:58 AM
Tainted's Avatar
have you done any mods since this started happening?
Old Sep 18, 2006 | 10:12 AM
KevsfastZ's Avatar
As far as I can remember it has been happing since I’ve owned the car, but I did port my throttle body.
Kevin D
Old Sep 18, 2006 | 11:15 AM
02SS#406's Avatar
I wonder if a plug wire is breaking down?
Old Sep 19, 2006 | 07:24 AM
KevsfastZ's Avatar
Well yesterday it did it again but in 3rd... seems to happen around 2grand when I let off the throttle lightly.... weird.
Kevin D
Old Sep 20, 2006 | 01:00 AM
DougsfastZ's Avatar
Check the main power lead off of the back of the alternator. Mine was hitting the return line on the power steering pump causing a short. My issue though was the motor cutting off for a split second on a 1 to 2 or 2 to 3 powershift.
Doug D
