Sponsored by: CARiD
fix-a-flat: does it work?
Old Sep 18, 2006 | 05:10 PM
2KnbmTA's Avatar
Default fix-a-flat: does it work?
well i just walked out side and on of my rear tires is deflated. im getting new ones soon anyway so i was thinking about just using fix-a-flat but wanted to see how well it worked. i have a 2 hour drive to make on it so should that be good enough?
Old Sep 18, 2006 | 05:29 PM
2001NBMZ28's Avatar
Never tried it but heard it works for small punctures - and your tire guy will hate you cause it makes a mess.
Old Sep 18, 2006 | 05:33 PM
texinteg's Avatar
It makes a mess and eats at chrome and aluminum wheels.
Old Sep 18, 2006 | 05:38 PM
2KnbmTA's Avatar
damn. so i probably should just take it off and get it fixed?
Old Sep 18, 2006 | 05:39 PM
2KnbmTA's Avatar
oh and how does it get onto the face of the rim?
Old Sep 18, 2006 | 06:23 PM
00T\A's Avatar
If you are in a bind i would use it but only as a last resort.
Old Sep 18, 2006 | 06:29 PM
DangerousCurvesZ28's Avatar
I work at a tire shop and from experience of seeing NEVER use fix a flat because it ruins the tire....if there is a possibility of using a plug to fix it instead of buying a new tire...it is no longer an option if you've used fix a flat...it slowly eats away at the tire therefore no shop will reuse that tire and it is definatley not a fix to a problem...id say see if you could get it plugged if not the buy a new tire...
Old Sep 18, 2006 | 06:46 PM
98hardtopZ's Avatar
yea, i would definately only use it as a last resort if your stranded somewhere and no spare....but right now i have crappy runflats! oh yea, and its a bitch getting those off the rim, its glues the tire to it..
Old Sep 18, 2006 | 06:56 PM
HotWhipT/A's Avatar
PUT THE CAN DOWN!!! I'd have to hate you. I work at a tire shop too. It does make a huge mess with your stuff, our machines, and smells horrible. Most of us don't clean up your rim or tire if you put that crap in. You paid for it, you'll get most of it back is how I see it. It does eat the wheel and tire too. Ever hear of chrome peel?
Old Sep 18, 2006 | 07:53 PM
Abe99's Avatar
Good to know guys, I was thinking of getting one of those cans for an emergency. I'll just invest in Jack.
Old Sep 19, 2006 | 09:12 AM
KillerKlown's Avatar
Besides, read the can label, its not made for low profile tires (if thats what your on). Plug it, save the headache.
Old Sep 19, 2006 | 09:24 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Bleh.
I have used it twice in ten years for emergencies, and it works fine. Tire place will charge like $10 to clean it out but what can you do.
My 95 Lumina had a flat, I used a can, it only got the tire up to like 18psi but it was enuff for me to get the car to a tire shop and get it plugged. I would only use it to avoid a tow not to drive around in for hours and hours.
Old Sep 19, 2006 | 10:17 AM
ChicagoTransAm's Avatar
I worked at a tire shop for years... First of all, it DOES NOT GLUE THE TIRE TO THE RIM. What the hell? lol... It won't hurt the rubber at all and the tire shop WILL reuse the tire. (unless they are pissed for you making a mess and want to screw you over)
With that, get the tire plugged... shouldn't be more than 20-30 bucks... Fix-A-Flat is only good for short trips and can break down with heat after time... Get it fixed properly
Old Sep 19, 2006 | 10:40 AM
99blue-Z's Avatar
Isn't there also mention of not using this stuff on speed rated tires?
I have been told by several people from various tire shops that this stuff is horrible to use on speed tires because it can affect balance and sometimes not seal the hole or cause a blowout. Just wondering though
Old Sep 19, 2006 | 10:43 AM
spy2520's Avatar
makes a mess. but at the tire shop i work at all we do is just wash it off. problems start when you use fix-a-flat and just keep airing up the tire every couple of days until it doesnt hold air well enough anymore...
Old Sep 19, 2006 | 10:53 AM
TurboZ28's Avatar
I wouldn't use it. I used it on one of my tires and now the chrome on the inside lip is peeling and won't hold pressure so theres a slow leak. Have to top it off just about everyday. Good thing I have a compressor.
Old Sep 19, 2006 | 12:01 PM
Exactly... it is supposed to be a temporary fix... and I do keep a can in my car just because I am often in a hurry and don't have time to play with putting a donut on.
On another note, I was just told how much tire shops are charging for patches! WTF!? It takes no more than 10 minutes to break a bead, ream the hole, apply the glue/patch, trim off the excess...remount the tire and balance it. My buddy just got charged 50 bucks!!!!
Old Sep 19, 2006 | 01:20 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
never used it on low profile tires..have used it 5-6 times on my trucks though..always worked fine..tire shop just cleans up the inside of the tire..no big deal ...as far as a mess/cleaning the stuff up--it is synthetic RUBBER...
Old Sep 20, 2006 | 11:00 PM
crazymofo1986's Avatar
i worked at a tire shop. would never use it. iv seen it eat chrome. its a bitch to clean. smells and burns what ever cuts u have on ur hand like a mother ******. also if u do use it tell the tire guy bc it can blind you.
Red Devil's Avatar
I have one of those mini air pumps and a reamer and self-vulcanizing plug kit in the trunk of each car. I've done quite a few without even having to dismount the rim.
