Sponsored by: CARiD
vibration
Old Sep 19, 2006 | 06:21 PM
fatjet00's Avatar
Default vibration
While on my way home from work cruising on the freeway, At around 80 mph I can feel a vibration feels like it's coming from thhe back. When axel bearings go out do they vibrate or make a roaring noise? I hope just my wheels and tires are out of balance, I'm not that lucky though. The car is a 00 Z28 A4. Thanks guys.
Old Sep 19, 2006 | 09:53 PM
todddchi's Avatar
You should notice noise long before vibration from bad bearings.
Anytime you notice a different vibration the first thing to check is to see if you threw a wheel weight. Usually it'll be pretty clear from the clean spot / outline where the wieght was. A vibration based at a specific speed should be checked with balancing first.
Old Sep 20, 2006 | 12:57 AM
Blk97WS6's Avatar
id say
1.check the tires, make sure you didnt throw a weight or they are unbalanced
2. make sure you rim is not bent
3.then check you driveshaft and u-joint
Old Sep 20, 2006 | 10:51 AM
JD_AMG's Avatar
Make sure you check the brake rotors, they may be warped (very common).
Old Sep 20, 2006 | 11:02 AM
chrisryn64's Avatar
sorry, wrong thread
Old Sep 20, 2006 | 11:21 AM
fatjet00's Avatar
Thanks for all the great suggestions everyone, I appreciate it.
