Sponsored by: CARiD
problem after changing the oil pan gasket
Old Oct 16, 2002 | 07:26 AM
BLKWS6's Avatar
Default OK....THIS IS MAKES NO SENSE????
Ok, changed the oil pan gasket on my buddy's 95 LT1 T/A. Got everything put back together. poured in all the fluids, checks all the wires and connectors. everything is plugged in and in the right order. simple. go to crank the car, and the car wont idle anymore. surges from 500-1000 rpms. motor sounds like it has a cam in it now? but is bone stock. just dies if you try and put it in gear. we did let it run for a few minutes to let the fluids circulate. Car has oil pressure, temperature is fine. cant figure it out at all??? anybody have any suggestions???? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Old Oct 16, 2002 | 02:50 PM
Shon Herron's Avatar
Default Re: OK....THIS IS MAKES NO SENSE????
Vacuum line is not connected right or more than likely you got a plug wire crossed. What all did you disconnect to do the gasket?
Old Oct 16, 2002 | 03:31 PM
BLKWS6's Avatar
Shon,
checked all the spark plugs. they are all correct. just rechecked the vaccum lines and they look correct also. Both lines are different size ports off the distr. ??? got any other ideas?
Old Oct 16, 2002 | 09:38 PM
The Big Show's Avatar
Was the oil pan gasket the only thing you changed?
Old Oct 18, 2002 | 10:13 AM
BLKWS6's Avatar
The oil pan, water pump and timing chain gaskets were all that was changed. nothing else. Anybody got any more suggestions?
Old Oct 18, 2002 | 11:09 AM
Ken95Z28's Avatar
Make sure you got the elbow on correctly.
The bottom of the elbow that connects to the TB is the gotcha. If there is a gap the car will not idle worth a crap.
Make sure also the IAC is plugged in.
Old Oct 21, 2002 | 02:38 PM
Gangly's Avatar
yes, make sure every connection between the MAF and the actual intake is connected properly. i didnt get the elbow on all the way and there was a tiny gap between the elbow and the TB and the car wouldnt idle for anything. check for crossed plug wires, IAT sensor, burnt plug wires, foul'd plugs, vacuum lines, etc. basically everything everybody has already mentioned.
<small>[ October 21, 2002, 02:40 PM: Message edited by: TAraysr ]</small>
Old Oct 21, 2002 | 08:57 PM
96SCTA's Avatar
I had a bad o2sensor one time and the car did the same thing. So if you have checked everything else check them out.
Old Oct 21, 2002 | 09:20 PM
BLKWS6's Avatar
ok. still not working. Checked the hoses, plug wires and the intake elbow. Still runs really rough and wont stay running on its own. it does have a good exhaust leak on the pass. side mainfold at the collector. Does anybody know if on these motors, if the car will crank and semi run if the distr. is not EXACTLY back in place. it looks like it has a 3 way key on the back that it could go on a few different ways. Or does anybody no where the vaccum lines that run off the distr. go to just so i can make sure they are hooked up right? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> i cant find a diagram anywhere on those. I used my TECH II on it and noticed th EGR ACTIVITY is 0. is this right for this LT1? also, the 02's are reading about 400or so at idle. Dont really now much about what these are supposed to show.....ANY HELP is GREATLY appreciated...you guys have been great so far....thanks alot.
Old Oct 21, 2002 | 09:24 PM
BLKWS6's Avatar
it does smell like its running really rich too. havent replaced the 02's yet. what should they be reading on the computer? anybody know?
Old Oct 23, 2002 | 07:52 AM
BLKWS6's Avatar
Ok. We have placed the EGR valve & position solenoid. Also have got the vaccum hoses hooked up correctly according to a diagram he found on another board. Car still wont idle on its own. I swear when you put it in drive you can hear the valvetrain going nutz. But the oil pressure is fine. We have checked and double checked everything. still stumped. <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> <img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" />
