Poly Trans Mount
Ok, I installed this over the weekend...easy job and really takes care of the shifter bouncing around. Now I'm getting a clunk sound that sounds like it's coming from a little behind it.....driveshaft area? It happens when I shift or take off, when it's transfering a load. I double checked the mount and surrounding bolts to make sure they were all tight, which they were. I'm not sure what it could be as I can't check it while moving lol, any ideas?
Posted this in LT1 forum too. It's currently jacked up, verfied bolts are all tight. No play in torque arm, just enough in driveshaft to seem like normal. Really have no clue what it is. Only happens when a load is placed on the drivetrain, ie takeoff and shifting
