Sponsored by: CARiD
need blinker help too
Old Sep 27, 2006 | 09:09 PM
gillahoon's Avatar
Default need blinker help too
ok i will try and start from the beging. the pass side front day time runnin light/blinker went out. So i changed the bulb work good for a while then went out again. I know the socket is pretty shitty i know i need to replace that. so i gave it a little tap it started working again. so now i park the car some out this moring and it wont start. so i notice the odo is out so i check the fuse and replace it now it starts. now all day no problem then on the way home tonight no blikers. Now there are no running light working but if u turn on the head lights they come on. but not when the parking lights are off. if u have the parking lights on and they are lit up and u use the blinker manually they dont blink. then i bang the gove box shut and the driver side starts to work but not the pass. when u look at the car with the lights on the driver side runnin light is brigher. Now the ? is what wrong if i replace the socket will ever thing get fixed or it a bigger problem.
