Sponsored by: CARiD
How do you know when your rear is going?
Old Sep 28, 2006 | 12:28 AM
Ironxcross's Avatar
Default How do you know when your rear is going?
I'm starting to hear goofy noises from the rear of my car, I'm just starting to wonder.
Old Sep 28, 2006 | 03:51 AM
CASHss99's Avatar
um basically it kan be many things like bad trans mount-drive shaft-u joints-gears and or bearings,,, what you wanna do is get under it check the u joints by seeing if the bushings are cracked or loose,, the trans mount if its cracked,,, or just give your rear end a change of fluid and see what you find in there its easy just take 2 hours of your time or sooner
Old Sep 28, 2006 | 09:15 AM
DomesticLS1's Avatar
my rear end has been making a whining noise 22 thousand miles now. Changed fluid still makes the noise. Not really worried about it going out anytime soon it has lasted this long. I seem pretty fortunate too considering I have drag radials and im constantly racing from digs. Guess my times coming...
Old Sep 28, 2006 | 09:48 AM
DJ_951's Avatar
when you no longer have forward movement with 2 wheels.
Check the fluid, burnt or low? Also there is a vent tube that falls off then the hole gets pluged that doesn't let the diff release pressure causing noise.
Old Sep 28, 2006 | 11:13 AM
TargetVice's Avatar
i just went through a rearend headache. making a hellacious noise from the rear and had all the bearings replaced. fixed the problem right up. if u change the fluid check the diff cover magnet for any metal shavings. if u see any you got bearings going out. if not then it could just be basic gear noise.
