Coolant leak at front of engine
. I drove to work anyway and raised on hoist. Looks like a coolant leak coming from the drivers side of the waterpump. What normally goes wrong with it- can you just replace the gasket? I am out of money for the time being so the least expensive way is what i am looking for. Or maybe I should car pool and save $$$ for repair and upgrades. So all of you that have seen this before, shine some light on what normally goes wrong...or recommend what should be done. I would save up for a new waterpump and belts.
Hmmm.....remove pump and clean gasket area, reuse steel and rubber gasket with rtv, free repair.
. I drove to work anyway and raised on hoist. Looks like a coolant leak coming from the drivers side of the waterpump. What normally goes wrong with it- can you just replace the gasket? I am out of money for the time being so the least expensive way is what i am looking for. Or maybe I should car pool and save $$$ for repair and upgrades. So all of you that have seen this before, shine some light on what normally goes wrong...or recommend what should be done.I decided to unbolt & remove the pump, 'hoping' it was the seal.
Unfortunetly for me, the seals were fine, it was the waterpump itself that was bad and leaking.
Since I had to to spend the cash anyway for a new pump, I decided to spend a few extra dollars now, and buy an EWP (with new gaskets - just in case :-)
Thanks for the input guys.
