Sponsored by: CARiD
power steering problems (00' WS6)
Old Sep 28, 2006 | 02:26 PM
michaelxx16's Avatar
Exclamation power steering problems (00' WS6)
I have a 2000 trans am ws6. I have just replaced the power steering pump and resoivor, but for some reason, the pump is leaking out around the cap or somewhere on the resoivor,(used resoivor but not the one from the old pump) I was thinking the rack might have something blocking the flow? or a stuck valve because of dirt? if anyone has any clue all help is greatly appreciated
thanks
Old Sep 28, 2006 | 02:33 PM
staringback05's Avatar
sometimes when a pump or rack n pinion are replaced by themselves....there can be shavings left over in either piece...did you flush the system when you replaced the pump?, like i said sometimes the metal will get into the rack and come back into the pump causing internal problems
Old Sep 28, 2006 | 02:46 PM
how do i flush the power steering pump/rack? it doesnt tell me how 2 in the haynes manual, so i didnt know how, also thanks again for the quick reply
Old Sep 28, 2006 | 03:25 PM
you cant really flush the pump per say....but you can plug the lines and just flush it like your flushing a brake line....i just replaced everything when my rack broke so i didnt really have to flush the system....its good to do it all otherwise like i said the metal shavings will get into either the pump and wear out the little gears, or get into the rack and cause it to stick....you can get a pump for about 190, and a rack for around the same....if you need to know how to replace the hardware just let me know
Old Sep 28, 2006 | 07:09 PM
i flushed it by unplugin the hoses, put like 2 bottles of cheap advanced auto power steerin fluid threw it then put in some valvoline stuff, ran perfectly so far since, only been like 3-4 hours so, hopein it fixed it by flushin it
Old Sep 28, 2006 | 09:31 PM
you see anything come out in the fluid....it wouldnt have been big, but more like a paste or something shiny....let very fine metal shavings?
