Sponsored by: CARiD
Cruise Control Help?
Old Oct 1, 2006 | 12:41 AM
Gun5's Avatar
Default Cruise Control Help?
Well before my motor/tranny/rear was rebuilt my cruise worked now it doesnt.. its all wired up correctly (glanced over it) it just wont work any suggestions for trouble shooting this ****?
thanks
Old Oct 1, 2006 | 01:02 AM
staringback05's Avatar
theres a small black box on the cables check the tension on the cable and make sure its adjusted properly.....also your throttle/cruise control module is on the passanger side of the car...trace the cables to the module, pop off the black top and make sure the gears inside are moving correctly...check back
Old Oct 1, 2006 | 01:12 AM
Gun5's Avatar
i know the electric box is on the drivers side under the intake in the wheel well basicaly.. ill check the passenger side stuff tomorrow.
Old Oct 1, 2006 | 01:18 AM
yea the passanger side box is the actual physical gears of the throttle/cruise controls....ive had issues before with that little box....but check also those little adjustment boxs actually on the cable sometimes they tend to get pulled and will not have the right tension on the wires
