Sponsored by: CARiD
Refilling coolant
Old Oct 1, 2006 | 05:15 PM
michaelxx16's Avatar
Default Refilling coolant
on my trans am ws6, it says there is a "special filling procedure" or something like that, for the coolant? whats this procedure? or do i just pour the antifreeze into the radiator?, thanks in advance
Old Oct 1, 2006 | 05:30 PM
2001NBMZ28's Avatar
After replacing my tstat I just let the car idle and kept filling, opened took more, kept filling...just make sure you get all the air out.
Old Oct 1, 2006 | 06:15 PM
2001somws.6's Avatar
I just replased my thermostat and the coolant. I filled it and then started the car and let it idle for a few. Turn it off and then checked too see if i need more and did.
I added some more and then took it for a drive. Not getting too hard on the car right away. Just a cruise. parked the car till it cooled checked it again and it was fine.
Old Oct 2, 2006 | 11:45 AM
Danny2tek's Avatar
If you have ramps put the front end on the ramps it makes it easier to purge any air pockets out of the system
Old Oct 2, 2006 | 01:18 PM
staringback05's Avatar
^^ good idea....keeps air pockets out of the back of the block
