Sponsored by: CARiD
Please Help!!!
Old Oct 9, 2006 | 01:22 PM
JD_Z28's Avatar
Default Please Help!!!
I noticed recently that when I floor it at high speeds that the RPM's shoot up when boost kicks in but the car isn't moving faster. I dought that the tires could be braking loose at 80mph in 4th gear. I get a vibration at first and then it disapears. I dought its the clutch because I have a spec 3+ w/2k miles on it and I only have this issue at higher speeds, is it possible a loose torque arm would cause this issue or do you think its something else. If anyone could help me I would really appreciate it.
John
Old Oct 9, 2006 | 06:08 PM
trackbird's Avatar
If it's a manual, if you were spinning the tires, the speedometer would show a higher speed (if you're spinning the tires 100 mph and the car is sitting still, it will still show 100 mph on the speedo). So, if the RPM comes up and the speedometer doesn't move, you're most likely spinning the clutch. If you're making "big power", you might have damaged/killed that clutch already.
Just my thoughts.
Old Oct 9, 2006 | 06:23 PM
30th droptop's Avatar
What he (trackbird) said. Also, I don't see how a loose torque arm could cause a problem like that.
