Sponsored by: CARiD
At Wits End.......... Please help
Old Oct 9, 2006 | 04:19 PM
Big Budda's Avatar
Question At Wits End.......... Please help
Ok i know this is an ls1 forum but ive tried everything and cant figure this out
I have a 97 s-10 2wd 4.3l vortec.
Heres the problem:
It was hesitating real bad so i figured bad plugs and wires(been awhile since last tune up) so i changed them.
It ran great problem solved right.....about a day later i threw a low voltage to my mass airflow sensor...looked under the hood and i forgot to plug it back in.
As soon as i pluged it in the truck died.So i bought a new maf sensor...That didnt work...It runs great with it not pluged in but as soon as you do it hesitates real bad again
Any suggestion where i should go for here???
Old Oct 11, 2006 | 06:12 PM
Big Budda's Avatar
bump
Old Oct 11, 2006 | 06:52 PM
gnomee's Avatar
Are you throwing any codes?
Old Oct 11, 2006 | 07:03 PM
Big Budda's Avatar
not when the maf sensor is pluged in
Old Oct 11, 2006 | 08:05 PM
taintedmeat's Avatar
Maybe you need to let it idle for a bit with the maf plugged in before you try driving it.
Old Oct 11, 2006 | 10:38 PM
00HARDZ28's Avatar
Is the motor running when you plug the maf in???? I would diconect the battery for a few minute to let the computer reset. Then make sure the maf is pluged in the start. good luck
