Sponsored by: CARiD
engine dieing
Old Oct 10, 2006 | 11:05 PM
LT1bird's Avatar
Default engine dieing
My car seems to have these fits latley and they have been getting worse. when i am running down the highway my car will all of a sudden start to jerk and studder like it is running out of fuel. It will do this a few times and then stop. Also when i slow down for a stop light or when i am in a parking lot it will have these same symptoms and then die. I have replaced the plugs and fuel filter. Any other ideas i am taking it to a garage on friday but i figured i would ask. Oh and my fuel pump seems to be priming. But could it be in the stages of going out ? The fuel filter was really bad when i changed it so i thought i had it fixed..... anyway if you have any ideas i greatly appreciate it.
Old Oct 11, 2006 | 01:26 AM
staringback05's Avatar
check your injectors....and just because the pump is priming doesnt mean it is functioning properly....are you throwing any codes?
Old Oct 11, 2006 | 07:30 AM
trackbird's Avatar
Might be worth it to check fuel pressure as well.
