Sponsored by: CARiD
02 Trans Am Electrical Problems
Old Oct 13, 2006 | 01:47 PM
Trans Am Dawg's Avatar
Default 02 Trans Am Electrical Problems
Ever since I first bought the car i've experienced electrical problems. Every once in a while the drivers window won't work, (does it every once in a while). The dealership replaced the altenator thinking it solve the issues. All the cars lights will come on, ABS, Brake, Service, all of them. Also the lights on the exterior and interior will blink and fade. Why is this doing this it seems to do it most when its cold. Also the blinker for the turn signal works when it wants to...
Old Oct 13, 2006 | 02:30 PM
Mr. Brett's Avatar
Sounds like a BCM going bad...
Old Oct 13, 2006 | 02:43 PM
what is a bcm?
Old Oct 13, 2006 | 04:40 PM
SSNISTR's Avatar
Originally Posted by Trans Am Dawg
what is a bcm?
Body control module.
Old Dec 9, 2006 | 05:17 PM
SuperC1's Avatar
I doubt if the BCM would cause those type symptoms I would say it is something not regulating voltage like it should. Like a bad ground connection or loose posi cable.
Old Dec 9, 2006 | 07:13 PM
01WS6/tamu's Avatar
A bad body ground can do all of the above and drive you up a friggin wall trying to fix it. good luck on this one
Old Dec 11, 2006 | 10:54 AM
98ws61le's Avatar
i agree....i would start with the underhood grounds....
