Sponsored by: CARiD
Oil Change light?
Old Oct 14, 2006 | 03:33 PM
quickws60423's Avatar
Default Oil Change light?
Change oil light wont turn off even though i hit the odometer/oil reset button? any help
Old Oct 14, 2006 | 03:43 PM
2001NBMZ28's Avatar
It should - key was on and you pressed and HELD it down for a few seconds? You can also do it by turning the key on, don't start car and fully depress the gas pedal 3 or 4 times. Won't flash but should be off on your next start.
Old Oct 14, 2006 | 05:28 PM
WS64LIFE's Avatar
not to hijack the thread or anything, but what do you do to keep it off? it always comes on when i turn on the car and stays on for about 15 mins.
Old Oct 14, 2006 | 05:37 PM
2001NBMZ28's Avatar
Even after resetting it? Just reset it with the pedal method or trip/oil reset button. Mines only come on a couple times, not for 15 min though...last time it stayed on after startup went off before I got out of a parking lot. Reset it when I got home.
Old Oct 14, 2006 | 09:46 PM
WS64LIFE's Avatar
stupid thing hardly ever goes off. it doesnt throw any codes. it just stays on.
Old Nov 22, 2006 | 07:58 AM
Flamin' bird's Avatar
Bringing this back to the top because I have the same problem. I've hit the Trip/Oil reset button so many times....held it in for 30 seconds or more (suppose to be only 12) and it wont go out
Old Nov 22, 2006 | 01:32 PM
2001NBMZ28's Avatar
Key in the RUN (don't start car) position first? Or try key in RUN (don't start car) and depress the gas pedal fully 3 or 4 times.
