Sponsored by: CARiD
Started not working, need a wire diagram
Old Oct 20, 2006 | 08:09 PM
RUNINHOT's Avatar
Exclamation Started not working, need a wire diagram
Here's the deal. My starter is not engaging. Trying to trace a wire and looking for a diagram of starter wires. Not the big one from the batt, but the other that tells it when to engage.
Power to starter relay is there.
Starter fuse is fine and power going through.
NO power making it to the started itself.
What I am looking for is were the started wire goes after it leaves the relay and what all it goes through before it gets to the starter.
If any one has a wiring diagram for it, please post it or link. Thanks
Car's a 02 Trans Am 6-speed
Old Oct 20, 2006 | 08:41 PM
tc3's Avatar
tc3
here ya go, i use a 97, im assuming the 02 conversion was just the front end...
this is a big picture, soo you need to save the image to computer and use windows picture viewer(winxp) to view the picture and control zoom...
Old Oct 20, 2006 | 08:46 PM
tc3's Avatar
tc3
well now im just confused as of wtf your car is soo im gona put up an 02 one as well...
Old Oct 20, 2006 | 09:41 PM
RUNINHOT's Avatar
Thanks for posting that up, exactly what I need. I just got another T/A and this one is a real 02. Havent even fired it up yet.
Where do you find the wiring diagrams like the one you posted.
Old Oct 21, 2006 | 07:59 PM
tc3's Avatar
tc3
si(service information) from service.gm.com, unless you have close friends that are gm techs(others might have alldata) you wont have access to it...
if you want them you can buy a service manual or for shitty wiring diagrams you can get a haynes/chiltons manual...
Old May 31, 2007 | 11:49 PM
mymechanic's Avatar
Thank you so much. Diagram is exactly what I needed. I am working with a 2000 camaro I assume that the second diagram will get me in the ball park.
Old Jun 2, 2007 | 02:56 PM
Robins Midnight Blue's Avatar
mymechanic--- I have a 2000 Camaro also. I am having trouble starting the car when its hot. I have replaced the battery and the starter. when I drive anywhere, I have to let the car sit 30 min or more before she'll start. Any ideas?? Would a bad nuetral switch cause this?
