Sponsored by: CARiD
SES engine code P0134 throwing
Old Oct 21, 2006 | 02:46 PM
Tx02ssm's Avatar
Default SES engine code P0134 throwing
I had both banks coding and went and bought two new Bosch front O2's for my 02 camaro w/LT's - installed them and am left with the 134 code. I also had a bad MAP sensor code throwing - I installed a new MAP sensor (biatch is on the very back side of the intake mani - hell of a lot of work just for that fokker) - so what is ledt to check? Get under tha car and check the installation, the wire harness plug and so forth to make sure all is well - anything else? Any easy way to check that the plug is live? Thanks for any help guys - stevet
Old Oct 21, 2006 | 04:21 PM
staringback05's Avatar
so your cars running rich?...what exactly is wrong?
Old Oct 22, 2006 | 12:05 PM
Tx02ssm's Avatar
Actually at vatozone the computer gave this message for the code --> P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1) so it is as if the O2 sensor were not there at all - the O2 is bad or the wires or connector is bad or worse a problem somewhere in the wire loom itself......just looking for any suggestions here.
Thanks - stevet
Old Oct 22, 2006 | 01:55 PM
just replace them....its usually the o2 itself....i believe a good o2 is a bosch 13111...not sure of the part number but i think thats it....
Old Oct 22, 2006 | 04:10 PM
Tx02ssm's Avatar
Forgot to mention that I just replaced both O2 sensors - w/long tubes I have only the two fronts - good suggestion though - appreciated
