Sponsored by: CARiD
Throttle Position Sensor
Old Oct 24, 2006 | 10:00 PM
waterbug1999's Avatar
Default Throttle Position Sensor
Do you think it could be the problem?...
For some reason, the pedal sticks so the car keeps going (like cruise control) till I step on the gas real quick to make it release. It does not stick when the car is off, and it sticks whith the car RUNNING and the throttle cable off. So, It has to be the TPS Right?
Any thoughts?
Old Oct 24, 2006 | 11:45 PM
staringback05's Avatar
do not drive the car anymore until you get this resolved.....id start with that, if that has no effect....check the little bosch unit cruise/throttle control on the passenger side of the car...ull see the cables running to it and youll notice that if the little gears arent working right the throttle will not close or open and your cruise will not work either....check back
Old Oct 25, 2006 | 12:00 AM
No, I am not driving it.. It started doing it the other day and its back in the garage
It does not do it with the car off. So, that tells me its electronic??
It still does it with the car running, even when I take the throttle cable off (give it gas by hand from under the hood). So, with the cable unattached, the throttle still sticks. So, that would lead me to think, SOMEHOW, the sensor is causing it to hang up (only thing left). I did take it apart and look at it, nothing noticable wrong, put it back together and it still sticks. I just dont see how a TPS can cause the TB to stick???
How much do the TPS cost?
Old Oct 25, 2006 | 12:15 AM
GOaT Cheese's Avatar
Me either, I would be shocked if the TPS was actually holding the throttle blade open. The throttle blade or housing must be bent or warped. It doesn't do it though if the engine is off? very strange
Old Oct 25, 2006 | 12:18 AM
not sure exactly on the cost but that sounds like thats it.....give it a try and check back
