Sponsored by: CARiD
headlight gear question
Old Oct 26, 2006 | 02:55 PM
dxd's Avatar
dxd
Default headlight gear question
hi all
i replaced my drivers side headlight motor with the brass gear about a year ago..now the grrrrr noise is back when i close the lights...any thoughts..should i buy a new motor or is this unit fixable..anyone else encounter this
D
Old Oct 28, 2006 | 07:11 PM
zach_ws6's Avatar
oh man..bummer. the motor itself is probably fine. did you make sure that the metal tabs were pressed flush against the motor (just use a small hammer and a little punch)? if they werent, that causes too much play and even the brass gears will strip.
