Help troubleshooting clutch problem
Thanks in advance.
I appreciate the reply... but I ended up swapping all the flywheel assembly and hydraulic mechanism for some crisp, clean, LS6 ones. It's smooth as glass under my foot now. No chatter, and lots of grab
. Wasn't even half as hard as I expected to bleed either, and that's after draining all the burnt DOT-3 (or what was supposed to be DOT-3) and swapping it for some higher-temp DOT-4). The throwout was completely shot, and felt like rubbing two bricks together. The hydraulic portion of the throwout was melted to high-heaven (plastic retainer on the spring).
