Sponsored by: CARiD
Noise when I turn?
Old Nov 1, 2006 | 06:59 PM
Wingman WS6's Avatar
Default Noise when I turn?
I have an 01 WS6 and I'm gettin a low whining kinda noise. It happens when I take a turn to the right and it comes from the drivers side. It sounds like the power stearing pump but it dosent make the noise when I turn to the left. So I got under the hood and checked the fluid, the level is fine...Crawled underneath the car and found the gear boot was broken a bit and a bit of greass was coming out, but could that be the problem? Or a bad power steering pump? Thanks for the info!!
Old Nov 1, 2006 | 09:18 PM
camarojunky74's Avatar
i think you might have a problem with the rack and pinion, if it only whines when turning a certain direction than i think thats it, the broken boot could be the culprate thou if grease and dirt mix they could bind up the arm coming out and cause you a problem
Old Nov 3, 2006 | 07:47 PM
houseylou's Avatar
i have the exact same problem. does it keep making the noise even after you get out of the turn? could be a bearing
