I believe the manual calls for service at 65K, but I could be wrong. Anyhoo: Assuming you have kept up on the previously scheduled services, Check: steering knuckles lubed; power steering fluid still pink and at correct fill; coolant level correct and free of corrosion; oil and filter; transmission fluid pink and at correct level (auto or MN6); change your rear end lube if you haven't ever before; spark plugs changed if you haven't before.
If you beat on your ride often (drags, autox, street racer), check wheel hub bearing for excessive play (jack up car, grab a tire and wiggle it back and forth; if it moves appreciably, then check the "book" for max play. It ain't much). Oh, and check brake pads/rotors too.
