Sponsored by: CARiD
Squeaking pulley in Rain
Old Nov 7, 2006 | 06:54 PM
Jon7I2's Avatar
Default Squeaking pulley in Rain
Ok I know this topic is everywhere, but i still do not have a definite answer. I want to know why my my pulleys or belts squeak when iti s damp or raining out. They are completely quiet in every other circumstance. What does this mean? Should I just replace the belt, or is it actually a pulley? I took a tube and listened around down there, and the source seemed to b the crank pulley. Could it be that?
Old Nov 7, 2006 | 07:17 PM
notatruews6's Avatar
Has Unresolved Sales In Feedback/12 second club
It is caused by a worn belt, or a worn tensioner, or worn idler pulley. i would make sure that your crank pully is tight also.
Old Nov 7, 2006 | 07:35 PM
99corvette's Avatar
I also have the same proplem, but if you dont fix it it will start doing it all the time. I had the Chevy dealership look at it and they said that i needed a new tensioner pulley, idler pulley, and belts.
taintedmeat's Avatar
Usually cause by a leaky seal on one of the pulley bearings. Water/moisture gets in and at first, will squeal until it works its way out. Eventually, it will squeal every time until it warms up, and finally; it will just squeal all the time. One of your pulleys has signed its death warrant.
Old Nov 7, 2006 | 08:20 PM
Boodyrider's Avatar
Neat trick:
If it's not too far gone, you can add a lot of life to those bearings by using a tiny screwdriver to pop off the plastic seals, clan and repack. It's not always gonna work, but last I looked good grease was 2 bucks, and the pulleys are like 25 bucks each. if you are careful and use a TINY screwdriver, the plastic seals will pop right back on.
Old Nov 7, 2006 | 09:13 PM
zach_ws6's Avatar
i had a horrible sqeak when it was wet outside. mine was the a/c belt. now i am squeak-free!
Old Nov 13, 2006 | 10:09 PM
sp00rkz's Avatar
Quick question, how do you tighten the crank pulley?
Old Nov 13, 2006 | 10:20 PM
I always thought it was bs that replacing a belt could get rid of a squeaking pulley, thinking that a pulley will only squeak when the bearings are shot....but I just replaced my belt the other day and my squeak disappeared. Don't see how that could possibly get rid of it, but it did.
Old Nov 13, 2006 | 10:27 PM
sp00rkz's Avatar
it will be back. Thats what I did. I had a horrible sqeaking. replaced the belts. and a few days later it was back.
Old Nov 13, 2006 | 10:43 PM
Camaroz's Avatar
I had this problem... I solved it when I took my AC Compressor belt off (Compressor was shot).
Old Nov 13, 2006 | 10:55 PM
bradmb's Avatar
yeah, the bad bearing makes it harder to spin it, then the belt will slip.
if its the tensioner it should bounce the pulley up and down. next time it happens, pop your hood to find out which on it is.
Old Nov 13, 2006 | 11:00 PM
Camaroz's Avatar
I kinda figured that was part of the problem.
BTW, That little squeak got on my nerves so bad..
Old Nov 13, 2006 | 11:14 PM
bradmb's Avatar
i had my a/c compressor bearing go bad one time. it was the worst sound in the world. I immediatly replaced it. it sounded like a dying pig.
