Sponsored by: CARiD
Ta Drl Bulb Change?
Old Nov 9, 2006 | 03:39 PM
superdrake06's Avatar
Default Ta Drl Bulb Change?
how do i change my DRL / turn signal bulb on my 01 TA? Thanks
Old Nov 9, 2006 | 07:21 PM
Pewterpower's Avatar
Underneath the bumper, below the DRL, you will see an access flap cut into the cowling that is held on with 2 10mm bolts. Undo the bolts, drop down the flap, and you will see the socket and housing.
Old Nov 9, 2006 | 10:32 PM
KameleonTransAm's Avatar
You can also reach in to the empty hole below the DRL and undo the socket. Pull out the bulb through the hole then replace it and place it back into the socket. I do it in less than 20 seconds now I've done it so much
Old Nov 10, 2006 | 12:04 AM
taintedmeat's Avatar
You'll eventually end up changing the socket......and when you do, you'll end up with several extra inches of wire, enabling you to pull the socket out the "vent" underneath, and work on it right there in front of the car.
Old Nov 10, 2006 | 10:08 AM
Yeah i just had all my sockets changed 2 weeks ago, and one bulb ALREADY went out. sucks
