Sponsored by: CARiD
Please help me with a misfiring problem
Old Nov 11, 2006 | 06:28 PM
199TAmaster's Avatar
Default Please help me with a misfiring problem
My car is yet again missin. I know for a fact that something is getting wet. I just need to figure out what i need to replace. Im headed to get new o2 sensors and harness cause one was close to dragin the ground would this cause it to miss. It wount miss until i drive it about 2 minutes this it starts bad. It usually stops in a day but has been goin on for more than 3 days now and i also noticed a weird smell in the air comin from the vents. Ok last night i went and put it up on jacks, got underneath it and checked the wires going to the o2s, I did not however change the o2s as they were 70 a piece. I found that the wires from the sensor on the driver side were touching the header and had been burned(well 3 of the 4 atleast) so i cut and spliced those back together and it still missed when i started it. However I drove a few miles and it went back to normal. Later on it started again so, I dunno if maybe the plug wires or maybe the sensor is bad, is there a way i can check the o2s? Any other ideas? help me
Old Nov 11, 2006 | 08:08 PM
t t t
Old Nov 12, 2006 | 08:49 AM
WILWAXU's Avatar
Lets see if someone in Maintenance & Repair can help you out.
Old Nov 12, 2006 | 10:16 AM
staringback05's Avatar
im assuming your talking about your front o2's.....thus, you should just go ahead and change them, im surprised that your not throwing a code...or maybe you just didnt mention it...usually when the o2s are going bad a code will be thrown...go ahead and change the wires AND the plugs....come back and tell us whats going on
Old Nov 12, 2006 | 11:58 AM
2001NBMZ28's Avatar
Just the the heck of it check your ENG SEN fuse. Buddy of mine lost his reverse lockout (M6) when it blew because of the 02 harness arcing/melted against a header. The MAF/02/skip shift/reverse lockout/brake switch are all on the same circuit.
