Sponsored by: CARiD
blower motor, where is it?
Old Nov 17, 2006 | 02:28 PM
nebur8's Avatar
Default blower motor, where is it?
my a/c makes noise when it turns on. depending what speed it is on it speeds up or slows down. i believe there is something wrong with the blower motor. i have not had a chance to find it yet. can anyone point me in the right direction?
thnx
Old Nov 17, 2006 | 02:52 PM
2001NBMZ28's Avatar
Does it do it with the AC off and still make noise at different fan speeds? Had leaves in mine before. It's under the dash, passenger side. Just unplug the wiring connector, remove 3 screws and the whole unit pulls right out.
Old Nov 17, 2006 | 05:22 PM
nebur8's Avatar
yes just with the blower motor on. definitely sounds like there is something in there. is the blower motor in the engine bay or in the cabin? how difficult was it to get to?
Old Nov 17, 2006 | 05:27 PM
2001NBMZ28's Avatar
Easy to get to, it's inside the cabin, passenger side.
Old Nov 18, 2006 | 01:18 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Once you pull the plastic kick panel down under the passenger side dash, you can't miss the motor. As said, it's 3 screws and it pulls right out. No biggie.
Old Nov 18, 2006 | 08:16 AM
bradmb's Avatar
yeah, youll need to remove the kick panel, then remove the panel under neath he glove box.
when i changed out mine, i had leaves and stuff in the blower.
