Sponsored by: CARiD
LCA Bushing Lube
Old Nov 20, 2006 | 08:27 PM
planemech2's Avatar
Question LCA Bushing Lube
How do you lube the stock LCA and panhard rod bushings? Mine are quite noisy. Do I need to replace?
Old Nov 20, 2006 | 09:29 PM
Pewterpower's Avatar
There should be a Zurk fitting for a grease gun.
Old Nov 20, 2006 | 09:35 PM
staringback05's Avatar
not on the stockers....you might want to go ahead and just get you a new set from one of the sponsers, they come with that fitting, there solid, and they have different bushings
Old Nov 20, 2006 | 09:38 PM
That's twice now that I've done that........... I read things too fast.
True, the stockers are non lube, but that shouldn't stop you from hitting the bushing with a can of silicone spray or WD 40.
Like Jacob said, a pair of aftermarket LCAs are not that much and will make a world of difference.
Old Nov 20, 2006 | 11:46 PM
taintedmeat's Avatar
White lithium grease
Old Nov 21, 2006 | 04:12 PM
planemech2's Avatar
Thanks for the replies. I'm sure I'll replace in the future.
