Sponsored by: CARiD
rear end service
Old Nov 23, 2006 | 11:42 AM
terry02's Avatar
Default rear end service
Does anyone have a write up about doing your own rear end service like what the dealership would do. I tried a search and that turned up nothing.
Old Nov 23, 2006 | 12:15 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
No need for a full write up. It's very simple. You just pull the diff cover (10 bolts), let the fluid drain out, remove any old gasket material, put the cover back on with a new gasket, pull the fill plug on the right side top of the diff, fill with fluid (80W90 dino for '98 or 75W90 synthetic for '99+) and 4 ounces of GM limited slip additive till it pours out the fill plug (about 1.75 quarts).
The end.
Old Nov 25, 2006 | 03:18 PM
_JB_'s Avatar
I thought stock 10 bolts didn't have a fill hole?
Old Nov 25, 2006 | 03:25 PM
RPM WS6's Avatar
Then how would you get fluid back into it? They all have the fill plug on the forward side of the axle near the upper passenger side of the diff.
It's a drain plug they don't have stock. The aftermarket covers usually do have that though.
Old Nov 25, 2006 | 03:29 PM
_JB_'s Avatar
ah ok. I thought GM might have had them on a stand facing down and put fluid in them like that. I've never looked close at the 10 bolt, so I didn't know.
Old Nov 26, 2006 | 12:38 AM
autotrix's Avatar
Closed ex-Sponsor Account
You could also rig up a way to suck and fill the differential fluid from the fill hole. Sounds hard but very possible. There are "Flush" machines at local shops that essentially do just that if you absolutly don't want to pull the differential cover.
Old Jan 3, 2007 | 02:46 PM
Black02Bird's Avatar
i have an 02 trans am with a 10 bolt and it took me a hell of alot more that 1.75 quarts to fill that ******.... whats the most fluid you have ever heard it using?
Old Jan 3, 2007 | 05:25 PM
jimbo98z's Avatar
We had one of those machines at my shop and I hated the thing. I would always pull the cover whenever possible.
To add to RPM WS6: Don't forget to wipe all metal off of the magnet on the diff cover (if the stock 10-bolt has one, I forget ) and wipe out the inside of the housing with a rag as well. Get as much of the old junk out of there as you can.
Old Jan 3, 2007 | 05:46 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
Old Jan 3, 2007 | 06:42 PM
98camaroLS1M6's Avatar
The end.
Why dino oil for 98s? It recommends 75w90 in the manual and as long as it has the lsd additive, it is good, right? I have been using 75w90 synthetic for years and no problems.
Old Jan 5, 2007 | 11:28 AM
98ws61le's Avatar
dino in 98 due to the fact its standard with the auburn which uses clutch packs...99+ have the torsen standard......... and also screw the suck machines.... with the cover off you get a change to for wear on the ring and pinion and give a good overall look..also you can check the magnetic for any unusually amount of metal particals..... u cant do this with a sucky machine
Old Jan 6, 2007 | 04:37 PM
jimbo98z's Avatar
Agreed.
