Alternator going bad?
I would be hesitant to blame an alternator for the problem you are describing. The vehicle will continue to run with the alternator providing no charging what so ever.
My 1998 Trans Am experienced and alternator failure while I was driving. I was able to drive over 10miles with a non functioning alternator.
Have you recently done any work that may have disturbed the wiring on your vehicle?
I'm not sure this question is posted in the correct forum. You may get more help if you post in the correct section or one of our MODS moves this for you.
Check out the cables, and report back.
