Sponsored by: CARiD
Greasing under the car?
Old Nov 27, 2006 | 02:15 PM
Candyredz28's Avatar
Default Greasing under the car?
Do any of yall grease or lube the car under like all the suspension stuff and joints, I notice that nobody talks about it.
Old Nov 27, 2006 | 03:26 PM
01Z28MN6's Avatar
i do about every 30,000 miles.
Old Nov 27, 2006 | 04:06 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Every 3-4 thousand miles when oil is changed....everyone should at least check at that interval......although I have all aftermarket greasable suspension parts.
Old Nov 27, 2006 | 04:31 PM
A-Dub's Avatar
If you car has stock suspension, it isn't servicable. Stock tie rods, ball joints, and u joints are all sealed. If you go with aftermarket parts, you will usually get greasable bushings
Old Nov 27, 2006 | 05:45 PM
davered00ss's Avatar
Moderator
Grease mine about 2X a year. Only 1 or 2 pumps of the grease gun.
Old Nov 27, 2006 | 09:53 PM
Flawless02SS's Avatar
I grease mine once a year, one pump for each fitting. I dont put many miles on my car per year. And he is right, if you have all stock stuff, there's nothing to grease.
