Sponsored by: CARiD
AIR leak?
Old Nov 28, 2006 | 10:06 AM
Y2K Z28's Avatar
Default AIR leak?
I was changing my plugs the other day and noticed that my AIR system is missing one bolt on the passenger side holding it to the manifold. I know this is most definitly causing a leak but what will it hurt? My car has been having a rough idle problem and at times has idled so bad it wouldnt even run below 900 rpms. Could this be the problem? I thought the AIR system is only used when the car is cold correct? If so why would the car continue to idle rough even after the AIR system is no longer needed? Any help would be greatly appreciated.
Old Nov 28, 2006 | 12:39 PM
shaun's Avatar
take on bolt out and go to lowes and match it up.
Old Nov 28, 2006 | 02:53 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Not entirely sure if that's what's causing all your idle issues, but it certianly isn't helping.
If the AIR pipe to manifold connection isn't sealed, then fresh unmetered air is entering the exhaust system ahead of the front O2 sensors. That means the O2 sensor readings will be showing leaner than they should (due to the uumetered air), thus the PCM will add fuel to bring them back in line. Problem is, the PCM is compenstaing for a leak rather than an actual lean A/F mixture, so now the motor is running overly rich. That can certainly cause some idle issues.
Old Nov 29, 2006 | 12:12 PM
Y2K Z28's Avatar
Thanks for the answers guys. I'm guessing that is also the reason why my gas mileage is very bad.
Old Nov 30, 2006 | 09:14 AM
Y2K Z28's Avatar
I fixed it and it seems to idle better now but not perfect. I think it may need plugs now. I think running too rich can cause plugs to mess up right? It's been this way for about 5000 miles so I think they may need changing too.
Old Nov 30, 2006 | 12:16 PM
RPM WS6's Avatar
Plugs can certainly get fouled from running overly rich. Can't hurt to change them.
