Sponsored by: CARiD
How do I diagnose bad PCV System???
Old Nov 29, 2006 | 03:46 AM
382WS6's Avatar
Default How do I diagnose bad PCV System???
Ok, here we go again. The car is burning oil. It doesn't smoke on start-up nor while driving. I had to add almost 3qts of synthetic between oil changes (3000 miles). it's not dripping anywhere. Compression check and leakdown test came back completely normal. I pulled the PCV valve and noticed that it was gunked up really bad with oil and it smelled really, really, burnt. I changed it but I'm not really sure what else to check in the PCV system. Anywhere else I should look? Could it be something else? I'm trying to fix it so I can sell the damn thing and get back to my Mopar roots. Any help would be greatly appreciated.
Old Nov 29, 2006 | 10:14 AM
wade99z's Avatar
There's another thread called "have you tried this PCV valve" that talks about using a different valve you can get from a GM dealer.
That PCV valve is just like the stock one except instead of the rattler, it's closed & hollow with a tiny hole where the rattler would otherwise be. I've had mine in for about a month, checking the oil weekly and have seen no significant oil consumption.
I had been about 1qt and some change low after 3000 miles using the German Castrol 0w30 (low oil light came on). So, I topped it off and changed over to this different PCV valve. You might check it out. The part number is in the other thread.
Old Nov 30, 2006 | 07:22 PM
382WS6's Avatar
Cool, I'll have to check it out. Is there anything else I should check? (PCV lines and hoses to see if they are clogged?)
