Sponsored by: CARiD
problems
Old Dec 10, 2006 | 11:18 PM
98charlize's Avatar
Default problems
i just took my car out after 1 1/2 years and theres something wrong. to start when you give 50% throttle the rear end clunks. and then at full throttle the tranny will bounce off the rev limiter unless you back off the gas. and then there's a missfire #8. what should i do or whats wrong. any help would be great.
Old Dec 11, 2006 | 01:33 PM
john shea's Avatar
The rear end clunking sounds normal, bouncing off the rev limiter does not
seem right unless it's not in d or od .Misfire could be a plug wire.
Old Dec 11, 2006 | 04:15 PM
staringback05's Avatar
after a year and a half....you needed to do a major tune....plugs, wires, ALL the fluids, fuel system purge....etc
Old Dec 11, 2006 | 08:12 PM
98charlize's Avatar
the rear end didn't do it before. but keep the feedback coming.
Old Dec 15, 2006 | 09:47 PM
98charlize's Avatar
o.k so it turns out all the plugs were bad and a coil had gone bad as well. the camshaft sensor also went bad. and there is a hole some where in the evap. the tranny problem has yet to be looked at. i was thinking a clogged valve body or something. it had a code for slipping tranny. ???? any ideas. thanks
Old Dec 16, 2006 | 11:43 AM
go ahead and flush it...you might need to take it somewhere to have it done...if the problem consist, just sport for a new tranny
Old Dec 16, 2006 | 11:07 PM
98charlize's Avatar
thanks
